PCI 1200 and pulse width
I am trying to measure pulse width from a digital signal using a PCI 1200 DAQ card and Labview 6.1, I have not been able to do so does anyone know if it is possible.
(2,904 Views)
There is a vi called "Measure Pulse Width or Period.vi"  under  " data acquistion----->counter"
Should be able to use it to measure a pulse width.  (at least at low frequenecy  (just refer to th help..)
Nidaq 6.9X is required.
If you for some reason installed Tradtional Nidaq  (Nidaq 7.x) it will probably not work since traditional Nidaq does not support the PCI-1200 series
(2,899 Views)
         hello if these using Win XP it is better than you install Nidaq 6.9.3f3 and its package labview6.1 that biene in the same page of NOR but first of all you must desinstalar nidaq traditional so that if it does not install driver 1200
Julian Andres Angel Jimenez
Fìsico
Aficionado al LabView Colombia
(2,778 Views)
