PCI-1200 daq function
Does anybody know what daq fuction that performs
the task of sending a binary patern to the digital I/O port.
Example:
If I what do sent 1 to PA0 , 0 to PA1 and 0 to PA2 simultaneously,
Is there a function that do that?
Thanks.
(3,677 Views)
"Tan" wrote:
>>Hi,> >Does anybody know what daq fuction that performs >the task of sending
a binary patern to the digital I/O port.> >Example: >If I what do sent 1
to PA0 , 0 to PA1 and 0 to PA2 simultaneously,>Is there a function that do
that?> >Thanks.
Hi Tan,
First, use "status = DIG_Prt_Config (deviceNumber, port, mode, dir)" to configure
the ports.
Use these arguments:
  • devicenumber: as specified in the measurement and automation explorer
  • port: 0 ( PA)
  • mode: 0 (no handshaking)
  • dir: 1 (standard output)
  • Then, call "status = DIG_Out_Prt (deviceNumber, port, pattern)", with
  • port: 0 ( PA)
  • patt
    ern: 10000000 (binary)
  • See NI-Daq help index -> 1200 Series Device Function List ->DIG_Prt_Config
    / DIG_Out_Prt
    for more info.
    In LabView:Tthe VI's will probably also be called something like"DIG_Prt_Config"
    and
    "DIG_OUT_Prt". Enter these same arguments into the VI.
    Hope it helps,
    Walter
    (3,677 Views)
    "Tan" wrote:
    >Hi,
    >Example:
    >If I what do sent 1to PA0 , 0 to PA1 and 0 to PA2 simultaneously,
    >Thanks.
    Hi Tan,
    the ports. Use these arguments:
    - devicenumber: as specified in the measurement and automation explorer
    - port: 0 ( PA)
    - mode: 0 (no handshaking)
    - dir: 1 (standard output)
    - port: 0 ( PA)
    - pattern: 10000000 (binary)
    See NI-Daq hel
    / DIG_Out_Prt for more info.
    In LabView:The VI's will probably also be called something like"DIG_Prt_Config"
    and "DIG_OUT_Prt". Enter these same arguments into the VI.
    Hope it helps,
    Walter
    (3,677 Views)
