PCI-1200 - not installed correctly
I want to install this device on a PC (Windows XP). Software delivered with this device is NI-DAQ 6.9.3. I can't install it because during initialising installation I'm getting an error. I've downloaded the newer version 7.4.1 but after restarting and installing the PCI device the driver is not installed correctly. Can someone help me to solve the problem.
Kristof
(2,763 Views)
Hi Kristof,
Thanks for your post and Welcome to the Forums!
The PCI-1200 is only compatible with NI-DAQ 6.9.3 on XP and most likely will not work with 7.4.1. What Error messages are you getting? Have you tried another PCI slot or another computer?
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(2,744 Views)
