PCI-4065 Not Found After Restart
I find that after restarting my computer, my PCI-4065 DMM is not recognized in MAX (where I gave it the device name "DMM"). If I look at the devices available in MAX, the device I named "DMM" is not there, and it has found a "new" device named "Dev1". If I delete the old "DMM" and rename the "Dev1" to "DMM" my program works properly. Is there a way I can keep this from happening?
Mark
(3,202 Views)
Hi Mark-
     This sounds like an issue with the driver.  Do you have any other devices in your computer?  Do they behave the same?  Which version of NI-DMM do you have?  If your OS supports it, it may be good to try upgrading your driver to NI-DMM 3.0.2.
     I hope this helps.  Have a great day!
Gary P.
(3,181 Views)
