(PCI-6014) AI_VRead function returns only -5V~+5V ranges.
After installing the PCI-6014 board, The Mesuremant Automation program work well between -10V~+10V range(Analog Input). But When I ran AIonePoint example, AI_VRead() function returns only -5V ~ +5V. It returns only 5V if I voltage more then 5V. In fact, I want to use this card in range -10V ~ + 10V. What can I do?
Thank you for seeing this. 🙂
(2,895 Views)
You need to use a gain of -1.
/* Nothing past this point should fail if the code is working as intended */
(2,891 Views)
