PCI-6014 not recognized by Windows 2000
I recently purchased and just installed a PCI-6014 in a new Dell Optiplex running Windows 2000 (sp2, we have stayed at sp2 due to problems we have had with sp3, sp4). On this same machine I have LabVIEW 7.0 with all the bells, including NI-DAQ 7.0. When I put the pci card in for the first time (and every one of many times I have restarted since) I NEVER have seen the "new hardware found" message come up. That's bad sign one. And the hardware device manager doesn't see it either (I think that would follow from no new hardware being detected..) Then I have run MAX 3.0 (also on the machine) and all it finds is this bizarre thing called "PXI System" under devices and interfaces. I also have an eight port serial card in this machine which MAX does see. I eventually removed both the Serial card and the PCI-6014 (daq card) and even after a restart the "PXI system" device or whatever STILL shows up under devices and interfaces... So I just don't know what that is?? Any help there would be appreciated.. So question one is what is "PXI system" likely referring to?? ..And to say more about it when you click the plus sign next to the "PXI system" entry it shows what appears to be a VISA resource name of PXIO::MEMACC. But again that shows up even with the card removed.
Back to the PCI card seemingly not being recognized I also read somewhere that there could be issues with this card and the new version of NI-DAQ 7.0. So I uninstalled that version from the machine and put on the version that came with the PCI card, NI-DAQ 6.9.3. But same story... Windows doesn't see it and unless this PXI system is somehow referring to this PCI card (??) then MAX doesn't seem to be seeing it either... Any advice on how to get this card up and running or how to truly troubleshoot to see if the card was dead out of the box?? ...Something I have never had happen before and somehow I still think it is just some silliness on my part...
Lastly, when I looked for the documentation for this card amont the long, long list of daq boards listed in the NI-DAQ software, nowhere did I find an entry for this PCI-6014 card. And I looked carefully. Does that mean I have a horribly old or outdated card??
Any help would be appreciated... thanks...
(3,003 Views)
I have now found that it is not the board but that I apparently have some dead pci slots on this new machine. When I removed the serial card again and installed this PCI-6014 in its place (ie., a confirmed good slot, the pci card comes up on both the windows device manager and on MAX. So please forgive the above long question though I would still like to know what the entry in MAX regarding PXI system is referring to?? Thanks...
(3,003 Views)
I am glad to hear that you got your card recognized correctly, too bad you have some bad PCI slots, though. The entry is shown by default and cannot be removed, but if you were to ever have a PXI chassis attached, your cards would be listed under this option, it is also where you would configure your controller and your chassis type. Also by default, there are no entries under this heading since you are not connected to a PXI system.
Andrew Mierau
(3,003 Views)
Much appreciated regarding your response about the PXI entry under devices in MAX... thanks...
(3,003 Views)
