PCI-6023E pinout
What are the ai channels in pci 6023E card, which ports are they. Can you give me a pinout detales? Im new to labVIEW. And can you sen me a tutorial to make a simple project using this card? I just got this card as a guift without any details. I installed labVIEW and DAQ. Now I ned to know how to use this card.
Thank you
(4,359 Views)
Hi punsith,
You can find the pin out diagram on the 6023E on Pg. 12 of its user manual:
https://www.ni.com/docs/en-US/bundle/370719c/resource/370719c.pdf
You can also open up Measurement and Automation Explorer (NI MAX), expand out Devices and Interfaces, right click your device, and view the Device Pinouts.
If you go to our example finder (Help > Find Examples), you can find examples of basic data acquisition tasks under Hardware Input and Output > DAQmx. We also have this getting started guide for programming using our DAQmx API. I hope this helps!
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
(4,358 Views)
ThankYou 😉
(4,304 Views)
