PCI-6024E error code device will not start [Code 10]
Loaded NI-DAQ traditional 7.4.1 onto HP with Intel Core Duo processor running 32-bit Windows XP. Installed PCI-6024E. Wizard finds device and driver but MAX doesn't find PCI board and error code comes up in Win harware wizard dialog box "Device will not start [Code 10]". Device manager locates PCI board correctly (slot,bus, device number and all codes). Driver found as well by Windows (...Win32\nipalk.sys) but driver and PCI board seem unable to find each other. Tried troubleshooting steps in Windows but unable to get PCI-6024E to be recognized by MAX.
Software on CD used. Also tried directly downloading NI-DAQ 7.4.1 directly from NI web site. No joy with either.
Has anyone else had this problem? Would appreciate any solutions.
Sleep doc
(5,025 Views)
The problem is known it is due to HP Bios. Please refer to this knowledge base.
Pierre R...
Certified LabVIEW Developer
(5,012 Views)
I had the same problem with a PCI-6036E on an ASUS M2V board. The recommended BIOS upgrade (now Version 1603) did not improve the situation.
Although I installed NI-DAQmx 7.0, I managed to solve the problem by installing the Core Drive Update (which claims to be usable for NI-DAQmx 8.3 and above) as described in the mentioned KB article.
Gx, cz.
(4,980 Views)
Hi All,
I had the same problem with a PCI-6233, PCI-8252 and other NI DAQ Card on NI PPC 2015.
Although I installed NI-DAQmx 8.7, I managed to solve the problem by installing the Core Drive Update (which shows "you already have a higher version of NI-PAL installed"). previously it was working fine with old DAQmx Software, but suddenly it goes down. even i had formated the PPC and installed WIN XP Professional and latest device driver "
February   2008". Still it shows same error code 10.
is there any solution for that..
Thanks in advance,
Alpesh Prajapati
(4,275 Views)
