PCI-6031E problem with AI 55
I am using the PCI-6031E to generate a sine wave and measure the phase and amplitude at 10kHz. I am utilizing all 64 of the AI channels in a test fixture. All of the channels work perfectly with the exception of AI-55. I have also connected an analog signal generator 10kHz sine wave to this channel and still no response. Using standard DAQmx VI's this channel was able to measure DC. But when I use the VI "Extract Single Tone Information N Chan.vi" in conjunction with standard DAQmx VI's all of the channels work except AI-55. Please let me know if you have any solutions. I would be happy to email you the VI I am using when I get an email response form you. Thank you for your time as it is greatly appreciated.
Contact Information:
Ryan Coutts
Test Engineer
Lectrosonics, Inc.
email address: ryanc@lectrosonics.com
(2,777 Views)
Hey,
Have you been able to acquire other then DC date using the MAX testpanels on AI 55 ?
Christian
(2,768 Views)
