PCI-6070e (PCI-MIO-16E-1) broken capacitors values ?
I have a PCI-6070e (PCI-MIO-16E-1) DAQ card. The problem is that some of the smd capacitors mounted on the back of the card are broken/missing. The card is:
Serial Number: 014B60A1
Version: 183455R-01
Copyright 2004
Made in Hungary
The broken capacitors are; C49, C57, C65, C66, C67, C100, C104, C111, C112, C113.
I believe that the card could be repaired, because it passes the reset, self-test and calibration tests. But I suppose its performance is affected by the missing capacitors.
I will be very thankful if someone could tell me what the values of these capacitors are.
(4,327 Views)
Hi 29f400,
If you suspect that any NI hardware is not functioning properly, the best thing to do would be to contact the NI technical support and get it repaired. You can contact the technical support through the 'support' option in your ni.com profile.Please let me know if you need more information on the repairs process.
Thanks and Regards,
Thanks and Regards,
Supreeth.K
(4,251 Views)
Thank you for the info.
Cheers
Zak
(4,241 Views)
