PCI-6132, device passes self test but can't do DAQ
Hi all,
I am using PCI-6132 and data acquisition is not working. It doesn't give me any specific error but just doesn't do DAQ.
Device passes self test and I can reset the device successfully on NI measurement and automation explorer.
However when I use continuous acquisition with test panel in same explorer to see amplitude vs samples chart, I neither see singal nor sample numbers change.
Again, it gives me no error.
I have already changed PCI slots, computer and reinstalled drivers so please let me know of other solutions.
(3,521 Views)
What makes troubleshooting difficult here is that there is no error. Can you try an example program in LabVIEW or C or whatever language you are using? Can you try self-calibrate from MAX? I would try those (noting any errors you get) and call our support line to see if the next step would be to return for repair. http://sine.ni.com/apps/utf8/nicc.call_me
(3,511 Views)
You first need to provide information on what pins you have wired up to where, type of source, input configuration (diff/rse).
(3,506 Views)
