PCI-6143 with quadrature encoders
Hello there,
does the PCI-6143 support quadrature encoders like advertised or does it not like the error message I got indicates:
Error message from angular encoder example
If this board supports quadrature encoders: How do I use it without the requested missing option?
Thanks in advance.
(3,177 Views)
Hi
as the message says AngularEncoder is not supportet with S-Series boards.
You can look here for an answer:
http://forums.ni.com/ni/board/message?board.id=231&message.id=6227&requireLogin=False
Or simply use edge counting and make the calculation in software.
Regards
DianaS
(3,146 Views)
I alredy tried edge-counting and it worked, but i waste four times the resolution. The following problem also applies:
If I used an external quadrature to up/down clock converter circuit (like described in the article linked in the other thread), how could I handle the Z-index signal to reset the counter to 0 in software?
(3,134 Views)
