PCI 6220 self test error
Dear All,
I am using PCI 6220 for one of my application. But my programme exe is not working with it.
When i am clicking on self test in MAX ,it will return following error:
the device self test has failed. the error report from device driver is as follows:
Error -50400 occured at self test.
Possible Reason: the transfer did not complete within the timeout period or within specified no. of retries.
I have installed DAQ mx 8.5 drivers again after uninstalling previous driver & i have changed pci slots also. but still it is showing the same error. the same error has also been shown when i am pressing device reset button in max.
I have also seen the same card is working in another machine. So my card is not faulty.
Kindly suggest me if any other solution i can try.
Thanks & regards,
Vipin Ahuja
(3,478 Views)
Dear vipin_ahuja,
a MAX database corruption can be a possible cause of this problem. Please follow the steps described in this document to correct it.
Daniel
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(3,475 Views)
Dear Daniel,
Thanks for your reply.
I have formatted the c drive of my pc & again installed max 8.5. If it is a max database corruption problem then this should be rectified.
is it possible that my max 8.5 drivers may corrupt from which i am installing them? or still i have to do the same procedure which you have sent to me.
Is it possible that my system pci slots does not get power from motherbord? How can i check them?
Vipin
(3,454 Views)
