PCI 6221 ERROR
I have PCI 6221 and i tried to check the all IO channels.
i am not getting AO as i tried to give voltage from DAQMAX.
I have tried to calibrate the card using DAQMAX and below Status code is coming.
Error code: 200545
Please suggest why this error is coming and how to overcome with this.
(2,301 Views)
This was the first result from a Google search: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N0zSAE
See if that helps.
(2,266 Views)
