PCI 6259 Differential Analog Input
For the NI PCI 6259, can you run differential and single ended analog inputs concurrently? Like 4 differential channels with 5 single ended inputs running at the same time?
Mike
(3,727 Views)
Of course. You don't mention which language you are using. If it's LabVIEW, you just use two separate DAQmx Create Channel functions.
(3,723 Views)
Hello Mike,
Thanks for posting on the National Instruments Discussion Forum.   Dennis is absolutely correct.  If you are using labVIEW, there is a knowledge here that has a little more details on how to program it.  There is also a way to do it in the DAQ Assistant by configuring each channel seperately.
Paul C.
Message Edited by Paul C. on 04-27-2009 01:49 PM
(3,704 Views)
