PCI-6259 and Matlab's Data Acquisition Toolbox
I am trying to use Matlab's Data Acquisition Toolbox to control a PCI-6259 card, but am having trouble with analog output. What I'd like to do is create an output in Matlab (a complex waveform, not just a sinewave or a step) and send it out through the analog output. With my old NI card (PCI-6052E), I did this from Matlab like this:
ao=analogoutput('nidaq','dev1')
addchannel(ao,0)
set(ao,'SampleRate',1000)
data=ones(1000,1)    %% Obviously this isn't a "complicated waveform" -- I'm just using something simple for illustration
putdata(ao,data)
start(ao)
stop(ao)
With the PCI-6052E, this works. But when I try it with the PCI-6259, I get the following error after the start(ao) command:
<< ??? The analog output subsystem of this device does not
<< support clocked generation.
<< You must use PUTSAMPLE to output data.
Is this right? It seems unlikely that an M-Series board can't do something an E-Series board did easily, and so I'm wondering if this is a Matlab problem. I should mention I'm using Windows XP, NidaqMX 8.6, Matlab R2007a, and DAQ Toolbox 2.10.
-- Niraj
(4,304 Views)
Your intuition is correct.  An M-series card should do what you expect.  I don't have one in my machine, but I simulated one.  In R2007b, Data Acquisition Toolbox 2.11.  I'll go back and check the R2007a version later today:
>> ao = analogoutput('nidaq','Dev3')
Display Summary of Analog Output (AO) Object Using 'PCI-6259'.
       Output Parameters:  1000 samples per second on each channel.
      Trigger Parameters:  1 'Immediate' trigger on START.
           Engine status:  Waiting for START.
                           0 total sec. of data currently queued for START.
                           0 samples currently queued by PUTDATA.
                           0 samples sent to output device since START.
AO object contains no channels.
>> addchannel(ao,0)
   Index:  ChannelName:  HwChannel:  OutputRange:  UnitsRange:  Units:
   1       ''            0           [-10 10]      [-10 10]     'Volts'
>> putdata(ao,zeros(1000,1))
>> start(ao)
One thing is to double check that your device ID is correct.  Would you be willing to post the results of the command DAQSUPPORT, or email them to me?
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
(4,284 Views)
I tried 7a as well, with similar results.  DAQSUPPORT might help pin down the issue.
-Rob
Rob Purser
MathWorks
(4,275 Views)
Hi Rob,
I e-mailed you the results of DAQSUPPORT. I didn't post it here because it exceeded the 10000-character-limit for posting on this board.
Thanks for your help,
Niraj
(4,263 Views)
Well, now everything works fine. That is, the same code I entered earlier does work with my PCI-6259.\
I'm not sure why it works now. The only thing I did was cycle the power a couple of times. But apparently, that was enough.
(4,243 Views)
