PCI-6363 for impedance
We are working on impedance measurement using the DAQ board as an FRA, generating and recording the frequencies on the card. We are moving into multiple response channels, and therefore need a morepowerful card (the PCI 6221 we were using is starting to exhibit limitations).
We are looking for at least 6 simultaneous channels, and 1 output channel, with the following capabilities:
Read and Generate data from 10kHz to 0.1Hz.
We have been advised about the USB-6363, but we are still open to discussion, let us know if you think of another card, with the same kind of price (1500-2500£). As it is quite a bit of money, we need to make sure it is the appropriate device.
Kentmey
Kentmey
(3,289 Views)
Hi Kentmey,
The best place to get information on our products is by contacting your local National Instruments Office. You will be able to get a contact number from the following website:
NI contacts: http://www.ni.com/niglobal/
Ben Clark
(3,265 Views)
