PCI 6601 daqmx
hi,
i was trying to use daqmx to simulate pci 6601. Is it possible to generate a virtual counter by adding to Count Edges (NI-TIO).vi and thn get back the time count.
Also, if i have to install the actual device for configuration in labview can it be done without the installation cd.
the count digital events file says the following:
Note:  Use the Gen Dig Pulse Train-Continuous example to verify that you are counting correctly on the DAQ device.
as i am new to daq can someone guide me around joining the two VIs. What i can't understand is how to use daqmx start task vi twice in one file.
Yatin
(3,085 Views)
This post has been answered here.
Ana P
(3,050 Views)
