PCI-6602 Buffered Position Measurement
Hi, I have two Encoders.
I need to do the 'Buffered Position Measurement'using PCI-6602. And both
encoder positions
should be read simultaneously.
I wonder if I could have some example VIs to easily start.
Thank you for your kind consideration.
(2,777 Views)
I am doing something very similar. There are a few examples available from the Knowledge base. There is an example called "Measured Buffered Position (NI-TIO).zip" available. All you need to do is choose the selected gate signal. You can use this as a start but it will need some serious development. Otherwise there is a serious lack of info on how to do similar things to this.. come on Ni help us out!
(2,777 Views)
