PCI 6602: Different HW-Trigger-Polarities not possible ?
i tried to synchronize two GPCTRs on a PCI-6602 Board using
a hardware-tigger-signal. Using NIDAQ6.7 i configured the
The START_TRIGGER_POLARITY for one of the counters to
ND_LOW_TO_HIGH and for the other one to ND_HIGH_TO_LOW.
But when i arm the counters by software the do not start correctly.
The whole thing works only if both counters use the same
Start-Trigger-Polarity. Is this a problem of NIDAQ or the PCI-6602 ?
'would be grateful for tips,
Steve
Message 1 of 1
(2,827 Views)
