PCI 6703
I am using an M series DAQ (PCI 6229) for which I have installed DAQmx 9.0.2. I also need to use PCI 6703 for with I need to install traditional Daq, 7.4.1 both devices are recognised and visible under both traditional daq and Daqmx. However the resources test failed under the traditional Daq and the device does not work. I have been told to reset the software but it didn't help. Any suggestions?
Best regards
Amir Fallah
(3,181 Views)
6703 is also supported by DAQmx...does your card work with the DAQmx driver?
(I'm just saying...if you have to use DAQmx in your program for the 6229...why not keep going to program the 6703)
-gaving
(3,172 Views)
