PCI-6711 was working with LV now isn't with new MoBo
I've got a tester with a single board computer running LV 6 under Windows 98. The PC has a NI PCI-6711 board along with a few other boards for data acquistion. I had to put a new single board computer in the unit and now all the boards work as before except the NI 6711. I can access the 6711 board with NI MAX, but not through my LV vi's. I've tried recompiling the vi's but LV still won't access the board. Any suggestions?
Thanks.
(3,083 Views)
Accepted by topic author 0048
Did the Device Number or Alias of the board change to something different after installation? You can check this in MAX. Verify your LabVIEW code is using the proper Device.
Any error messages when you run your vi?
(3,071 Views)
That was it! Thank you.
 For some reason, the new Mobo decided to make this device 3 instead of the previous device 1.
(3,066 Views)
