PCI 8511 and LV2009 FDS
I have to collect position information from a hydraulic cylinder which has a CAN bus interface. I am new to this and trying to get some information from the net. In the meanwhile I have planned to use the PCI 8511 for the hardware part.
I am using LV2009 FDS and would like to get some tips on the interface aspect. I still don't have the card into my PC and if I try to install the DAQMx drivers after installing the card would there be any relevant drivers that will get loaded ??
Thanks.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,081 Views)
I have located the CANopen LV Library and that seems to be the bundle  that I was looking for to work with PCI8511. However it also says
"The NI CANopen LabVIEW Library is a set of VIs you can use to create CANopen master applications that comply with the CiA DS-301 standard."
Now I have two components that have DS-408 and DS-306 profiles. What does this mean ? Will I be able to use the library for my requirement ?
Raghunathan
(3,067 Views)
