PCI DAS 1200
I am using PCI DAS 1200 and my task is to acquire the signal from sensor and sample it and process it . How can i do this?
Agnivesh
(3,472 Views)
You would access the driver from Measurement Computing - the maker of the board. Not National Instruments so I don't know why you posted here. If you have a question specific to whatever programming language you are using, then use a more appropriate forum/board.
(3,469 Views)
I want to know that what are the parameters i have to consider to making such type of VI .i am sending you my vi which i made in labview 7.1 . it is working but i cant able to store the sampled data and how can i see the sampled waveform. please help.
Agnivesh
(3,454 Views)
