PCI-MIO-16E-4, NI 183139B-01 and SC-2050
Hi all,
i have to work on an old machine but i have some problem to understand the pinout of this. My system is composed by the board PCI-MIO-16E-4 connected to a adapter NI 183139B-01 so i can exit with a ribbon flat that reach a SC-2050 shield. I don't understand the pinout:
I have seen by the datasheet that the PCI have a pinout as in the image1 but in the SC-2050 this is change as image2. Where the pins are swapped? In the adapter?
(5,042 Views)
Hi ypkdani,
it looks like the pins are swappend in the adapter. If the adapter is compatible with the board then you should just worry about the pinout of the SC-2050. Did you try it out? Do you read it correctly?
(5,007 Views)
No i have search the schematics of the adapter but i didn't find anything
(5,004 Views)
But did you try connecting a signal and reading it from LabVIEW or MAX? Do you read anything?
(5,000 Views)
Your cable must do it. The DAQ card has a 68 pin connector and not the typical 50 pin for those old e-series cards. An ohmmeter would tell you all that you need to know if you don't have any documentation.
(4,995 Views)
Thanks!! i will check this.
(4,976 Views)
