PCI-QUAD04E
Hi everyone,
I have a PCI Quad04 card which already has 37 pins. I want to connect jumper wires directly to these pins. Is it possible to plug jumper wires directly into the pins of the PCI Quad04 card? If not, what would be the best way to make this connection? (I do not have a C37F-4X9F-1M)
Thanks in advance for your help!
(553 Views)
You can plug in jumpers directly into the connector if they fit snugly, but you will risk a loose connection.
https://files.digilent.com/manuals/pci-quad04.pdf
The best thing you can do is get a 37-pin D-SUB connector breakout and use it to connect the signals if you cannot buy the original accessories.
Santhosh
Soliton Technologies
(540 Views)
Hi there,
You can attach female jumper wires to the pins in the 37-pin connector, but I would advise against it, you might end up with a bent pin which ruins your 37-pin connector.  You can buy a NI 9923 terminal block, or buy one of these terminal blocks from Amazon, they are cheap and will get the job done.
https://www.amazon.com/Anmbest-Solderless-Terminal-Connector-Breakout/dp/B082DYC6QG/?th=1
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
(483 Views)
