PCI card in slim-case machines.
Does anyone know if I can fit the PCI-6036e [http://tinyurl.com/47snr (actual link: http://sine.ni.com/apps/we/nioc.vp?cid=11913〈=US)] in this slim-case Dell machine [http://tinyurl.com/6jcc8 (actual link: http://www1.us.dell.com/content/products/productdetails.aspx/dimen_4700c?c=us&cs=19&l=en&s=dhs&~tab=viewstab#tabtop)]?
Thanks-
-dennis.
(3,678 Views)
If you check the specs page of the PC at http://www1.us.dell.com/content/products/productdetails.aspx/dimen_4700c?c=us&cs=19&l=en&s=dhs&~tab=specstab#tabtop , it says that they only have PCIe slots and the National Instruments card you mentionned is not PCIe compatible.
The dimensions of the PCI-6036E are 17.5 by 10.6 cm or 6.9 by 4.2 in. You can use these dimensions to ask Dell if it would fit in their machine once you find one that would work with the PCI-6036E.
Hope this helps.
Serges L.
(3,669 Views)
