PCI card used for A/D & D/A w/ filter at one time
Thanks, now quite clear with most of the parts except for 1302
Does 1302 have analog output or can it be connected to SCB-68 which I planed to use?
Message 11 of 12
(791 Views)
Hi Stan,
Fortunately, this issue has already been answered by John in his previous post.  You are using a 68-Pin M-Series Device, and the 1302 is a 50-pin connector.  Therefore, it will have pinouts as described in the pinout document for the 1180, that John linked in his post, which does include AO0 and AO1, as John also mentioned.  You will not need the SCB-68 at all, and you will make the phyiscal connections on your 1302 for the Analog Output.
Best,
Adam
Adam
Academic Product Manager
National Intruments
Message 12 of 12
(771 Views)
