PCI6229 Interconnect
HI:
For a test fixture I am developing I need to interconnect it to multiple PCI6229 style cards. I would prefer to use the high density connector found on the NI PCI cards at my test fixture and then use a simple straightthru interconnect cable.
1. Do you have a Mfg/MfgPN for the PCI DAQ card connector
2. Can you suggest a source (even NI) for a straight thru cable (1-2m) for such a configuration.
thanks
(3,297 Views)
Hey amatt,
The connected on the 6229 is the 74337-0015 from Molex.  We don't sell a straight-through cable that would plug two of these connectors into each other because none of our products require such a connections.  You could look online for a cable that connects the two together.  An alternative connection method that we do sell cables for would be to purchase SHC68-68-EPM cables and then purchase the connector.
-John Sullivan
Problem Solver
(3,279 Views)
