PCI6534 DAQ not functioning with DAQmx driver 9.2.3
I upgraded my DAQmx drivers from a older verion (compatible with Labview 7.0) to DAQmx 9.2.3 as part of an upgrade to Labview 8.5 (from 7.1).  Labview 8.5 runs correctly; the DAQmx software driver is recognized by the Measuremtns & Automation Explorer 4.7.4.  However, the NI PCI6534 card is no longer recognized by the M&A explorer showing no device adress or serial numbers.  The explorer recognizes the card is there, but contains no properties.  Using the legacy DAQmx driver the card was recognized and funtional.  How do I get the PCI6534 card functioning using the DAQmx 9.2.3
(2,880 Views)
Hello Chip1960,
Can you tell me what Operating System you are working with? Do you get any errors when your try to select the properties?
Jignesh P
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(2,867 Views)
