PCI7030/6040 recognised by XP but not by MAX
My PCI7030/6040 card is recognised by the device manager of Windows XP but not by MAX 2.2 / NI-DAQ 6.9.3. It uses a non shared IRQ (10).
What do I have to change ?
(2,404 Views)
Do you have the LabVIEW Real-Time Module and the Real-Time component of NI-DAQ installed. Most likely, you installed NI-DAQ before LabVIEW RT and NI-DAQ did not install the RT component. You can check this by modifying the installation in Add/Remove Programs and adding the RT component if it isn't present.
JR A.
Application Engineer
(2,404 Views)
