PCIE-6251 how diagnose which pin connector card is output
Hello.
I have question regarding card PCIE-6251. I don't know how diagnose which pin connector card will be set when I use programme show below
I'm stunent:)
(2,983 Views)
Open Measurement and Automation that is there on your desktop and have a look at the Task configured in there. When you look into it, you should be able to find the pin it's corresponding with. Also, be sure to go through the following document to understand what you are working with:
Getting Started with NI-DAQmx
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,979 Views)
