PCIe- 6320 technical problems (Windows 7 & XP, Crashing, Errors after logging out)
My organization is having trouble with the PCIe-6320. Our drivers were updated last month, and that was all we could find for this issue, but it didn't fix anything. Here's a rehash of what is happening:
We have two machines using your software and firmware that are having problems. One is running Windows 7, the other is running Windows XP and both have the issue. Sometimes they crash and the crash records indicate that niraptrk.dll is responsible. Also, when logging out of the machines, we occasionally get error messages related to bad memory references.
The daqmz 9.X driver is installed on both machines.
The power supply is capable of supporting the machine and memory card.
The card is not shorting due to contact with the motherboard.
The machine is not overheating.
We do not have any similar set ups that work.
(3,612 Views)
Hi LASP,
Could you describe exactly what you are attempting when the program crashes and if and any specific error messages you are recieving when logging out? Also what version of DAQmx (9.8, 9.7, etc.) are you using? And what are you attempting to do with your program?
Evan See
(3,581 Views)
