PCIe-6321 alternative
Hi NI Community,
We want to change PCIe-6321 DAQ card to PXI compatible card. Do you have any suggestion on best replacement for PCIe-6321?
We have been using PCIe-6321 with SCC-2345 carrier, do we need the different for carrier PXI DAQ card?
(2,298 Views)
At a very high level, it looks like the PXIe-6341 will work for you.  You should double check the pinouts to make sure.
(2,284 Views)
