PCIe-6323 cards have a setoff when measuring analog input voltage
I used a function generater to input a 1V sine wave(setoff 0) into ai0 of BNC-2110 switching to the ground, but the test panel displayed a sine wave ranging from 4-6V.
And the setoff may vary with time, sometimes it can be 5V. Is there any way to avoid it?
(2,453 Views)
Hi cjr189:
Try changing the terminal configuration, I have seen this issue before and it was caused by a wrong setting of the terminal configuration.
For instance refer to this Knowledge Base article, even though it makes reference for USB devices, this might as well happen in other devices.
(2,419 Views)
