PCIe-6341 Matlab compatibility? Optimized for Matlab?
Matlab says it has support for NI PCIe DAQ, but NI didn't list Matlab as one of the compatible software for its products. So i like to know if NI optimized its product to be used with Matlab.
I am using Matlab 2014a, the software recognizes the card and is able to connect to it. However the speed for one of the commands i am using is extremely slow. This particular command is called 'inputSingleScan'. This commands' 32 bit legacy interface counterpart perfoms much faster, but with a MCC card instead.
(5,160 Views)
It is the rsponsibility of matlab to optimize their product with NI hardware, not the other way around. 😉
Have you tried to contact them instead?
(5,158 Views)
Matlab does have support for this particular DAQ, but NI didn't list Matlab as one of the compatible software.
(5,151 Views)
NI makes exactly one driver - DAQmx. This is used by all software. If you are having a problem with matlab, you should be asking them about the problem.
(5,144 Views)
