PCIe 6536 Sample Clock Use
Callum,
Here is a configuration that may work for you.
  •  Setup your update line with the 20MHz timebase.
  •  Setup your axis line with the 100kHz timebase.
  •  Arm start these two counters.
  •  Export via RTSI the 100kHz to the 6536 and use it as the sample clock to over sample by 5x.
  •  Use the Decimate(continuous) VI to get your data back to 20kHz sampled data.
Dustin D
Message 11 of 11
(790 Views)
