PCIe6361
We bought one of this unit and would like to take advantage of the high speed switching of the analog output. How can we do this?
I need to send Labview command to this instrument as follows:
Multiple point output command, approximately 1200 data point within 300 microseconds. We will be using the analog signal from this device to control MOSFET device. Please see attached graph of what we would like to accomlixh, IXTN sheet.
(3,130 Views)
Start Here:
LabVIEW -> Help -> Find Examples -> Hardware Input and Output -> DAQmx(be sure you installed DAQmx) -> Analog Output -> Voltage (or current) - Finite Output.vi
(3,118 Views)
