PDA memory card memory
I know there is a LabVIEW PDA function that returns the overall memory in use and remaining in a PDA, but are there any functions that can determine how much memory is remaining in just a PDA memory card plugged into the PDA?  I'm using LabVIEW 7.1, LabVIEW PDA Module 7.1, Pocket PC 2003 2E, Dell Axim x50, and SanDisk 2G memory card.
thanks in advance,
Luan
(3,856 Views)
Luan,
Currently there is no function that would allow a PDA to determine how much memory is remaining on a memory card.  There may however be a Windows CE dll available for you to call that would allow you to determine how much memory is left on your card, which would obviously be much more difficult.  When LabVIEW is targeted to LabVIEW for Windows there is a function under the File I/O >> Advanced palette called Volume Info that allows you to determine disk size, as well as used and available amounts.  Unfortunately when you switch execution targets this function is no longer available.
Andy F.
(3,842 Views)
thanks, Andy.
i'd pretty much come to the conclusion that there wasn't a function for what i was looking to do, so i've been working around it.  still, i appreciate the response.
all the best,
Luan
(3,837 Views)
