PID in Simulink with USB 6009 NI
Hi Folks,
I got a problem with the USB 6009 NI when I connect a PID Controller to an Analog Output in the Simulink.
I would like to know how do I use the PID Controller without select a Discrete-Time in the Time Domain (in the PID Controller Block Configuration), because I need to use a Continuous-Time.
Thank in Advantage.
Best Regards
Pedro Ivo Allevato
(5,743 Views)
Hello Pedro,
Based on your picture, I believe you are using the Data Acquisition Toolbox for MATLAB®.This product was created and is currently supported by The MathWorks, Inc. As such, I recommend contacting them with any further questions or issues with this toolbox.
That being said, I found a DAQ in Simulink tutorial that contains your exact error (page 24) and a potential solution (using an Embedded MATLAB function with a PUTSAMPLE operation). Also, you can easily use the USB 6009 to perform PID control using:
LabVIEW PID & Fuzzy Logic Toolkit
MATLAB® is a registered trademark of The MathWorks, Inc. Other product and company names listed are trademarks and trade names of their respective companies.
Andrew Brown
Software Engineer
(5,721 Views)
Hi Andrew,
Thanks for the reply, I had this Tutorial in which you said, It's fantastic! I've solved this problem using a Zero-Order Hold Block to discretize my signal instead using the Embedded Block, because my Matlab doesn't have this one.
I have one more question, do you have some materials about Level Controller using USB 6009 NI with Matlab (Simulink)?
Thanks in advantage.
Best Regards,
Pedro Allevato
(5,701 Views)
Hello Pedro,
The following may be useful:
KnowledgeBase 23KH8MG4:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PkkSAE&l=en-US
Tom L.
(5,683 Views)
