PID motor control with tach feedback
I am needing help with PID tuning. I have followed the procedures, to the best of my knowledge, and can not get my PID to tune correctly. The system is a USB-6009, DART MAG-20 tach, and a DART 125DV56G motor speed controller. I am utilizing 0-5vdc input to the controller from DAQ's AO0. If I use a control slider in labview it works without oscillations. But I can not get the PID to stop oscillating. My VI will be attached. Any help and suggestions are greatly appreciated.
(3,185 Views)
First off, I did not look at your vi because I do not have LabVIEW on my networked machine.  But thanks for attaching it.
Now, PID tuning is something of a black art at times.  If you have never tuned one you can go crazy at first.  Check out this link http://en.wikipedia.org/wiki/PID_controller  There is a lot of good info and a tuning section near the bottom which should help.
You say that you can't get the PID to stop oscillating, but how big is it?  There will usually be a small amount even when tuned, it will look like a very slow sine wave.  You also have to think about how fast you run the PID because that is how fast it can react to changes depending on tuning.
(3,166 Views)
