PWM Current Measurement
I want to measure current for a small DC motor driven with a PWM signal. Working voltages are less than 2 volts and expected current is less than 1 amp. I have a M series 6233. I am using a shunt to measure my current and am feeding it into two analog inputs. I need to convert the PWM pulses into an analog wave to display on a graph. The net question is how do I convert PWM pulses into an analog wave form?
Mark
(5,196 Views)
What programming language are you using? If it's LabVIEW, then selecting multiple points to read with the DAQ Assistant or a DAQmx Read set for a waveform and 1 channel/n samples is what you should do.
(5,183 Views)
Thank you for your response.
I am using Labview. And I am reading in the voltage drop across my shunt. I do the math in Labview and convert the shunt voltage to current and display that result. This provides me with a wave form that follows the PWM voltage supplied to the motor. I need to have an analog signal as I have a few crossovers to evaluate between current and voltage.
Mark
(5,155 Views)
From your description, you do have an analog signal. Please attach an image of the block diagram and front panel.
(5,149 Views)
