PWM Generation ?
Does NI has any DAQ Board product that generates PWM signals ? I know about the FP-PWM-520.
(3,259 Views)
Hello;
Depending on what is the output voltage or power you need on the PWM signal, you can use one of ours E-series boards' counter. I'm attaching a Labview VI that uses a counter to generates a PWM signal on the counter output. You can get more details about our e-series boards on our web site.
Hope this helps.
Filipe Altoe
(3,259 Views)
