PXI 6221 Analog Output
of the questions.
I am trying to troubleshoot AO channels on our SC-2345 board, which is connected to PXI-6221M DAQ. AO is connected through SCC-FT01 to BNC cable. Voltage was measured by Fluke 76 multimeter.
I tried creating a virtual channel and also used "Cont Gen Voltage Wfm-Int Clk-Non Regeneration.vi" supplied in the DAQmx examples. I used both J17 and J18 slots on the SC-2345 to get any output through that channel, but without any luck so far. In order to check that SCC unit works correctly I connected SCC-FT01 to J10(Digital I/O) and was able to get 5V TTL signal reading. So that part is out of the questions. If somebody can give me a hand regarding this issue I would really appreciate that.
Message 1 of 1
(3,056 Views)
