11-10-2013 11:13 AM
I'm using a SCB-68 connector block to connect a Honeywell FP2000 series pressure transducer to a PXI-6224 DAQ module. The transducer requires a 9-28vdc power supply, but the connector block seems to only have 5v pinouts. Do I need to use an additional power supply for the transducer?
Solved! Go to Solution.
11-10-2013 12:26 PM - edited 11-10-2013 12:27 PM
Yes.
Be sure to connect the ground of the power supply to the AI Gnd of the 6224.
Lynn
