PXI-6229 Analog output function generator
I am using the PXI-6229 card analog output channel for sinewave generation, but i get the following error:
Error -200432 occured at DAQmx Create Channel (AO-FuncGen).vi
Selected physical channel does not support the output type required by the virtual channel you are creating.
Create a channel of an output type that is supported by the physical channel, or select a physical channel that supports the output type.
Property: AO.OutputType
You have requested: Function Generation
You can select: Voltage
However, it works fine in the NI MAX test panel for 6229 and generates a sinewave. What could be the issue? Kindly let me know.
Priya.
(3,326 Views)
(3,320 Views)
