PXI - 6255 Differential inputs pinout
I was wondering how the DI pinout would be on the 6255 DAQ module as in the spec sheet ( http://www.ni.com/pdf/manuals/371291h.pdf ) on page 20 it shows AI pinouts which I would assume also will translate to DI somehow. Thanks
(3,215 Views)
Here's another thread you might want to read...http://forums.ni.com/t5/Multifunction-DAQ/differential-pinout/td-p/2118722
(3,212 Views)
