PXI-6259 code
I'm looking for PXI-6259 DAQ sample code for saving me some time to start from scratch.  I fond one "daqmx_finite_aquisition.llb " in ni.com website, but there is nothing in the folder when I open it by Labview8.5.
Someone get some working code ?
Regards
Samuel
(3,448 Views)
 Samuel,
What do you need the code to do?
Also, could you post a link to the page where you found that  "daqmx_finite_aquisition.llb"?  I'd like to check that .llb to make sure it is posted properly.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,435 Views)
Samuel,
You should have many examples installed on your computer that should be of help to you.  These should get installed when you install DAQmx.  If they are not there, you might want to attempt to repair your DAQmx installation.  Usually they are installed at a location like the following:
C:\Program Files\National Instruments\LabVIEW 8.5\examples\DAQmx
These should be easy to find with the help of LabVIEW's Example finder.  To do this go to the help menu and follow the following links:
Help->Find Examples->Hardware Input And Output->DAQmx.  From here, the examples should be categorized by the functionality (ie... Analog Generation, Analog Measurements, etc).
Hope this helps,
Dan
(3,425 Views)
