PXI_Clk10 can't be found in PXI6115.
I deleted the AnlogStratTrigger function of master device in the example, then it runed with a warning information.
Possible reason(s):
Measurements:clock rate specified is less than the minium conversion rate of the ADC. your data may be invalid.
Message 11 of 13
(949 Views)
I define the ai/starttrigger as PF10, now i'm sure the problem comes from the "master timebase rate", it always said the clock rate specified is less than the minimum conversion rate of the ADC.
thank you so much for your reply.
Message 12 of 13
(940 Views)
It works now. You are great! Thank you very much for your reply agian.
Message 13 of 13
(933 Views)
