PXI chassis with DC option
Hi all,
I would like to select a PXI chassis for high sampling data acquisition (4 channel, 2MHz and above).
Are there any recommended PXI chassis with DC battery option so that I can power up the chassis even in the remote area?
Is PXI e-1062Q comes with the DC option?
Thank you.
(4,075 Views)
hyin,
There are DC Chassis that NI makes, such as the PXI-1036DC (6 slot PXI), the PXI-1031DC (4 slot PXI) and the PXIe-1066DC (18 slot PXIe). However, none of these will have any battery built in, they are just designed to be supplied by a DC Source. The closest thing you will get to the 1062 is the 1066, more slots but it's PXIe, which it sounds like you need.
Aaron W.
CLA, CTA and CPI
(4,062 Views)
